License unbinding to 3cx FQDN
Discussion in '3CX Phone System - General' started by xserius, Mar 20, 2018.
  1. xserius
    Oct 11, 2016
    10
    I have bound an license to a FQDN from 3cx but i want to use a local FQDN and DNS now, however when i use the same license by an install it won't give me a choice anymore.
    Is there a way to remove the FQDN from the license?
  2. fidoka
    Mar 17, 2016
    Yes, you have to open a ticket to the support and ask for the unbinding.
    That's the only way
  3. xserius
    Oct 11, 2016
    10
    I thought you could release the FQDN from the license in the partner portal.
    But i only see our license (and can release it) and not that of the customer.
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,250
    202
    If you have access to the 3CX portal for that user, https://customer.3cx.com/ , you will find a option to release the FQDN
    Partner logins do not have this option
  5. xserius
    Oct 11, 2016
    10
    I never made a customer portal, where can i do this or can't i do this anymore?
  6. Saqqara
    Mar 12, 2014
    1,250
    202
    When you register the license, you fill in the end user details with an email address - the client portal info gets emailed to this address
    You do not create the client portal, it is automatically done for you
  7. xserius
    Oct 11, 2016
    10
    I see the license under license in my own customer.3cx.com but i dont see where i can unbind it.
    Does the server need to be online ?
  8. xserius
    Oct 11, 2016
    10
    I checked and its the e-mail adres of us (for that license) but i didn't recieve an e-mail with info.
  9. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    If you have not received an email with the credentials then you need to contact our costumer support department so they can try and help you. Check your junk or spam folder before doing so though and make sure that the email has not been misplaced.
    https://www.3cx.com/company/contact/
