Licensing just turned on?
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 1, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Was the Free vs. licensed version functionality just turned on?
    In the middle of designing, I rebooted my machine and suddenly most of it is disabled and it wants a license key.
    Where have you put information about this? I need to keep moving on this so please let me know asap.
    Email me sq_swsdev.com
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The beta period expired on Sept 30th. You will have to activate the VAD in order to continue using the full functionality.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Please tell me where to do that
  4. VAD_Support
    Aug 6, 2009
    690
    You need to purchase a VAD license. The final release will be very very soon, so you can activate that version.
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Yes I am ready to purchase one right now. Is the current one permanently locked then?
  6. VAD_Support
    Aug 6, 2009
    690
