Licnese to use CRM API
Discussion in '3CX Phone System - General' started by rickytmp, Oct 7, 2011.
  1. rickytmp
    Oct 6, 2011
    13
    I would like to use CRM API to intergrate 3CX with our CRM, my question is do I need the 3CX CRM Integration Module license to use the API, since I only need the use API other then the Integration function.
    Thanks for any help.
    Ricky
