LIGAÇÃO EXTERNA RAMAL COM APLICATIVO FECHADO OU MINIMIZADO NAO FUNCIONA
Discussion in 'iOS' started by infomaniaco, Dec 27, 2017.
  1. infomaniaco
    Dec 26, 2017
    OLÁ
    GOSTARIA DE COMPARTILHAR COM VCS MEU PROBLEMA
    SO FUNCIONA QUANDO ESTOU COM O APLICATIVO ABERTO
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,367
    110
    Hello @infomaniaco,
    Can you please give us more details about this? What application are you using? What is not working as you need?
    Regards.
  3. infomaniaco
    Dec 26, 2017
    I have difficulties receiving calls.
    I'm with two iphones 5s
    one is with wifi and the other connected via 4g
    when I call the extension with the iphone on hold it does not ring
    but when I start the application
    he calls
    I think this is strange because it does not make much sense because I will not always be with the phone unlocked
    I have another question.
    does 3cx accept any ddns?
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,480
    67
    @infomaniaco
    I saw you reported the same issue about the Android client, so:
    - what version is the PBX you're connecting your clients?
    - the PBX has the latest push certificates installed?
