Limit call length per group
Discussion in 'Ideas' started by AlexHeylin, Oct 5, 2016.
  1. AlexHeylin
    Nov 30, 2015
    44
    9
    We have a requirement to limit the maximum call length only on outbound external calls from a specific group of extns. We cannot use, and have had to disable the default global setting of three hours as per client requirement. ONLY calls from the selected group(s) should be limited length. Thanks.
