Limit calls by group ?
Discussion in '3CX Phone System - General' started by shedster99, Jul 23, 2010.
  1. shedster99
    Aug 3, 2009
    28
    Hi all,
    is there any way we can limit the number of simultaneous calls by either a group of extensions or indeed an inbound DID/DDI ?
    Thanks in advance
    10,869
    304
    You probably need to clarify what you are trying to accomplish.
  3. shedster99
    Aug 3, 2009
    28
    Lets say I have a 3CX system licensed for 16 simultaneous calls and I "sub-lease" the system and services to 4 customers giving them their own simultanous call limits so as not to affect the other customers eg
    Customer 1 : 2 simultaneous calls
    Customer 2 : 4 simultaneous calls
    Customer 3 : 4 simultaneous calls
    Customer 4 : 6 simultaneous calls
    How do I ensure customer 1 doesn't make more than two simultaneous calls (even if they may have 3 or 4 physical extensions on the system) ?
    Thanks in advance.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    I would have to take a look at your setup and identify how it can we worked around, please generate your support logs by using the backup and restore tool and send it over to mf@3cx.com I will try and identify a workaround solution if this is possible according to your setup. Limit call groups has been done before but can be complex.
