Limit to number of accounts on Windows softphone?
Discussion in 'Windows' started by oguruma, Nov 12, 2017.
  1. oguruma
    Feb 18, 2017
    26
    I have a total of 5 extensions. I currently have 2 accounts added to my Windows softphone. Every time I add another extension (via email) one of the goes away. Is it supposed to be this way? Is it possible to have more than two accounts on the softphone?
  2. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hi oguruma,
    There is not such a limitation with the windows client. I currently have 6 accounts configured and switch between them. I would suggest you to uninstall and reinstall the 3cx windows client and try configuring again all 5 accounts using the confoguration file from the welcome email.
    You can find the latest installer here.
