Limitations of Windows XP
Discussion in '3CX Phone System - General' started by alex weber, Aug 14, 2010.
  1. alex weber
    Jun 20, 2010
    10,366
    227
    The 1 gig of ram may cause you some problems, depending upon how busy your phones are.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,405
    81
    Depending on the nature of the call, i'd say you MIGHT be able to get away with it with 6-8 Sim Calls.
    1Gb Ram should be enough to run WinXp + Phonesystem i'm just not sure how many calls the Cpu can take.
