Limitations of Windows XP
Discussion in '3CX Phone System - General' started by William400, Oct 2, 2006.
  1. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    What would be considered a reliable number of extenstions and lines on Windows XP?
    How would 6 PSTN lines / 2 VOIP providers and 15 extensions perform with a P3 900Mhz / 1GB RAM ?
