Line Configuration
Discussion in '3CX Phone System - General' started by pd2006, Mar 25, 2008.
  1. pd2006
    Nov 29, 2007
    What information do you put in for line configuration, i'm in the VoIP Provider Account Details.
    it asks for external number?
    Authentication ID?
    Authentication Password?
    Thansk for any help. As I'm learning as I go along so apologies if its a daft question
    Regards
    pd
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    You need to sign up with a provider i.e. voiptalk.org
    Then you get all the detail from them.
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    If you're located in the US get your VOIP number from freedigits.com; they are currently providing free accounts with real US phone numbers which allow for free, unlimited incoming calls. Makes life much easier if you can easily call in with your cell phone or desk phone.
    When you get your account, they will provide you with 3 pieces of info that you need to setup a line on 3CX or any SIP phone; sip proxy address, user/authentication id, and password. Then you're good to go and experiment all you want.
    Halea
