Line forwarding using voip boxes
Discussion in '3CX Phone System - General' started by kris, Jun 6, 2008.
  1. kris
    Jun 6, 2008
    :?: question... :?: is it possible to use setup two voip boxes in a way so that one box can be hooked up to a telephone line and be used as a means to make/ receive calls from another location?
    eg. if i have a extra line at work used for tech support but i have to be at the office to answer it, can i used one of the voip boxes and cofigure it and put it on that line and put the other box home and use it to receive the calls that go to the office at home.
    how can i do that if it is possible
    using quiptel VoIP boxes from orbitalcom.net
    gateway-linksys-3102
  2. nitup
    May 16, 2008
    16
    Properly formulated question is already half of answer.
  3. kris
    Jun 6, 2008
    srry what i meant was cud anyone help by posting the settings.... thanx
