Graeme
Thanks for the quick reply and to be honest i have not changed the RTP ports these ports were always open on the firewall since i had A@H and Trixbox.
For reference the 2 NIC's are 10.99.99.21 (this is what i want 3CX to use) and 10.99.99.16 - this is what it is using.
10.99.99.23 is one of the test Cisco 7940's
3CX used to work fine without any issues since the last 2 upgrades the problems have appeared, my log is:
21:03:22.061 ServRegs::checkExpiration [CM113000] Registration for sip:
[email protected] has expired
20:56:19.595 MediaServerReporting::RTPReceiver [MS105000] Call(2) Ext.301: No RTP packets were received on 00000004@:remoteAddr=10.99.99.23:28766,extAddr=0.0.0.0:0,localAddr=10.99.99.16:7006
20:56:19.564 StratLink:
nHangUp [CM104001] Call(2): Ext.301 hung up call; cause: BYE; from IP:10.99.99.23
20:56:06.618 MediaServerReporting::SetRemoteParty [MS010001] Call(2) Ext.301: Failed to update remote party attributes. No codecs intersection found.
20:56:06.056 CallLegImpl:
nConnected [CM103001] Call(2): Created audio channel for Ext.301
28766) with third party (10.99.99.16:7006)
20:56:06.024 StratInOut:
nConnected [CM104005] Call(2): Setup completed for call from Ln:10000@Sipgate to Ext.301
20:56:03.213 CallConf:
nProvisional [CM103003] Call(2): Ext.301 is ringing
20:55:57.107 MediaServerReporting:
TMFhandler [MS211000] Call(2) Ln:10000@Sipgate: DTMF (RTP) from 217.10.68.72:52008 arrived. in-band DTMF tone detection is turned off.
20:55:53.328 CallLegImpl:
nConnected [CM103001] Call(2): Created audio channel for Ln:10000@Sipgate (217.10.68.72:52008) with Media Server (10.99.99.16:7004)
20:55:53.250 CallConf:
nIncoming [CM103002] Call(2): Incoming call from 07801397739 (Ln:10000@Sipgate) to sip:
[email protected]
20:54:49.458 ServRegs:
nAdd [CM113002] Registered: Ext.301
20:49:01.152 MediaServerReporting::RTPReceiver [MS105000] Call(1) Ext.301: No RTP packets were received on 00000002@:remoteAddr=10.99.99.23:28762,extAddr=0.0.0.0:0,localAddr=10.99.99.16:7002
20:49:01.090 StratLink:
nHangUp [CM104001] Call(1): Ext.301 hung up call; cause: BYE; from IP:10.99.99.23
20:48:47.697 MediaServerReporting::SetRemoteParty [MS010001] Call(1) Ext.301: Failed to update remote party attributes. No codecs intersection found.
20:48:47.228 CallLegImpl:
nConnected [CM103001] Call(1): Created audio channel for Ext.301
28762) with third party (10.99.99.16:7002)
20:48:47.197 StratInOut:
nConnected [CM104005] Call(1): Setup completed for call from Ln:10000@Sipgate to Ext.301
20:48:41.165 CallConf:
nProvisional [CM103003] Call(1): Ext.301 is ringing
20:48:35.539 MediaServerReporting:
TMFhandler [MS211000] Call(1) Ln:10000@Sipgate: DTMF (RTP) from 217.10.68.75:54974 arrived. in-band DTMF tone detection is turned off.
20:48:30.866 CallLegImpl:
nConnected [CM103001] Call(1): Created audio channel for Ln:10000@Sipgate (217.10.68.75:54974) with Media Server (10.99.99.16:7000)
20:48:29.960 CallConf:
nIncoming [CM103002] Call(1): Incoming call from 07801 (Ln:10000@Sipgate) to sip
sipgate.co.uk
20:48:11.192 ListenConnect [CM114000] SL: connected promo-vm3:0/PHPExtension_0 at [promo-vm3:0]/PHPExtension_0
20:35:49.625 ClientRegs:
nSuccess [CM113005] Registration of sip:
[email protected] is successful
20:35:49.203 ExtLine::Register [CM110004] Send registration for "08450045941"<sip
sipgate.co.uk>
20:35:49.203 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='Sipgate'
20:35:47.953 StunClient:
rocess [CM115002] STUN resolved external IP=:5060 by server 80.239.235.209
20:35:47.906 ListenConnect [CM114000] SL: connected promo-vm3:0/VoiceBoxManagerService at [promo-vm3:0]/VoiceBoxManagerService
20:35:47.906 StunClient:
rocess [CM115001] Send initial STUN request to 80.239.235.209
20:35:47.796 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
20:35:47.578 IVRConnected [CM111000] IVR Server is connected
20:35:47.578 ListenConnect [CM114000] SL: connected promo-vm3:5483/IVRServer at [promo-vm3:5483]/IVRServer
20:35:47.437 CallMgr:
umThread::thread [CM100004] ** Enter DUM Thread **
20:35:46.906 DBA [CM109000] ** Database connection Ok **
20:35:45.953 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
20:35:45.921 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
20:35:45.843 CallMgr::Initialize [CM100002] Default Local IP address: 10.99.99.16:5060
20:35:45.765 MediaServerConnected [CM112000] Media Server is connected
20:35:45.765 ListenConnect [CM114000] SL: connected promo-vm3:0/MediaServer at [promo-vm3:0]/MediaServer
20:35:44.843 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
20:35:44.843 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
20:35:44.828 LoadLicenceInfo [CM100008] Licence loading error
