Line Keys on Polycom
Discussion in '3CX Phone System - General' started by dannybrook, Apr 23, 2010.
  1. dannybrook
    Feb 24, 2010
    43
    If I manually configure my Polycom 550 phones using the web GUI, I can successfully configure them to have four line keys for each user's extension. However, when using the 3cx to provision the phones, there is only an option for the BLF.
    Is there a way to edit the provisioning template to have it use all four line keys?
  2. dannybrook
    Feb 24, 2010
    43
  3. t4mack
    Jan 19, 2010
    56
    You should be able to edit this by going into the provisioning template (settings > provisioning template). Just select phones and the type of phone. You should have to edit the options under SIP Settings for Identity 1.
