Line Status is taken almost 2 minutes to appear
Discussion in '3CX Phone System - General' started by emerbrito, Oct 25, 2007.
  1. emerbrito
    Oct 24, 2007
    24
    Hi;
    Is that normal?
    Se software is installed in a Dual Xeon with 2 2GB Ram.
    The server performance is normal and everything i click responds fast.
    But... everytime i click on "Line Status" it takes about 2 minutes to appear.
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Got that onde here too.... but after a reinstall and a reboot all worked fine...
    Cheers
  3. emerbrito
    Oct 24, 2007
    24
    I'll try to reinstall it and reboot the machine.
    I can't register my broadvoice line, i went to the log and it shows:
    Do log says "Time Out"
    Do you think both problems are related?
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    I cant tell you if the problems are related or not... what i can say is, try to see if someone has already the configurations for Broadvoice and see if they match... just to see if everything is correct.
    Cheers
  5. emerbrito
    Oct 24, 2007
    24
    i'm using the default configuration for broadvoice, i only typed my userid and password. i already searched the forum for it but... didn't find anything. anyways, i'll keep searching.
    thanks for your help.
