Line Status
Discussion in '3CX Phone System - General' started by glynco, Jul 30, 2007.
  1. glynco
    Jul 14, 2007
    20
    How can I change the line CONNECTED status from YELLOW to other color?
    I need this because I am making a script to read the screen color and determine if the line is CONNECTED or just RINGING.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Isn't it easier to read 'Status:' value rather than color???
  3. glynco
    Jul 14, 2007
    20
    What is the variable than handles the status value?
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    <span id="lStateB100">Not registered</span>
    where 100 is you internal extension
    but i think it is easyer to read out the database then to extract the state from the webpage
  5. glynco
    Jul 14, 2007
    20
    What filename to edit?
