Line status
Discussion in '3CX Phone System - General' started by jantoney, Dec 14, 2007.
  1. jantoney
    Nov 20, 2007
    60
    Hi All,
    The hot topic today is line status!
    I know that there are hundereds of posts before mine on line status but none really fit what i want to know (i dont think!)
    I have a 3CX server (ENT) and Linksys SPA962 phones.
    Can anyone please tell me if each point is possible and how to do it...
    1. Can i display on my phone (using one of the 6 lights) the status of another user?... (avaiable/on phone/phone ringing)
    2. Able to press the button displaying that status to call that user.
    3. During a call able to press the button to transfer the call im on to that user
    4. Able to display the current status of an external (voip or pstn) line.
    5. Able to press the voip or pstn line status button to get a line out or answer the call coming in on that line
    6. Answer a call from another users extension. I know you can dial *10*<ext num>* to pick up the call ringing another extension however on the linksys phone pressing *10 thinks its a feature and doesn't actually send that through to 3CX
    im sure there are other cool things you can do but im really only interested in these features at the moment.
    thanks in advanced
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i try some points how to i try optional
    yes - using the BLF option - i don´t know exact the way for your phone
    Yes - if it is set up in the phone
    no - you have to press transfer and then the status button of the user you want to transfer to.
    sorry i don´t know
    sorry i don´t know - it depends on 4.
    not shure but you can edit the code for pickup if it is blocked by your phone (vertical service)
    not shure which version u use but i have in mind that the code was changed from v3 to v5.
    only a quickshoot and i have done this with GXP-2020 phone
    Andy
  3. jantoney
    Nov 20, 2007
    60
    Keep the ideas coming
    Hey Guys!...
    thanks to the guy that replied!...
    Can anyone else expand on any of the above questions...
    also has anyone got the BLF features working on the SPA962 phones??
  4. jantoney
    Nov 20, 2007
    60
    Answer from Linksys
    I seem to have made a friend in linksys and here is his responce re the SPA962 NOT having the BLF feature on the phone.. only on the SPA932 expansion!
    It's a Firmware Release which will be coming out with the next Major code release on the 962/942 to support BLF on the line keys around Mid/Late January. I had requested this a few months back.
    I have asked him for a beta copy of the Firmware so i can test with 3CX so we know that it will be compatable on release!
    I will keep everyone posted!
  5. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Re: Answer from Linksys
    Do you know if the firmware will also support 941s? Sometimes there are firmware releases for the 942s that don't make it to 941 (generally to do with the two Eth ports rather than SIP/Phone functionality).
  6. jantoney
    Nov 20, 2007
    60
    firmware question
    hey BJReplay
    Sorry what did you want put into the 941s firmware??
    Ill ask them if its in there... Just not too sure what you mean by..
  7. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Hi Jay, sorry, I wasn't very clear with my question !!
    You mentioned that Linksys were going to add BLF support to new firmware for the 942 and the 962. I was wondering if you knew (or could ask) if support for BLF for the line keys was also going to be added to the 941 firmware.
    The 941 and 942 phones have different firmware, as they have slightly different hardware.
    Thanks for following up.
  8. jantoney
    Nov 20, 2007
    60
    linksys....mmmm
    Well bad news all round... haha
    My reply from Linksys!
    Hi Jay,
    We dont have a Beta tester group, we have a team of guys who work on that internally.
    We won't have anything for the SPA941 I believe, as we have EOL'd that product in Australia
    Regards
    ** EOL'd = End Of Lifed (no more support) ** <- For thoes that didn't know!
    Sorry BJReplay... dont think your going to get much out of them this time... :( ... Time to upgrade maybe??
  9. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    4 - is shared line appearance. This feature has been requested and I believe that their is some rudimentary workaround for it. It has to do with split sip requests; however if you are coming from the old analog PBX world it is not currently working like that where you would see calls occuping lines 1,2,3 and 4-8 are available.
    5 - this also likens back to the old pbx days. VoIP systems have made this less useful as the real logic is built into the system. What would you gain by being able to dial out of line 3 vs line 4. As long as your users get a line that should be sufficient. Correct?
    In any event you could always setup numerous providers (both VoIP and Analog via gateways) and specify a prefix to dial out to each.
