Line Status
Discussion in '3CX Phone System - General' started by vincelarkin, Sep 14, 2008.
  1. vincelarkin
    Aug 12, 2008
    23
    I notice that time to time, the line status shows a call is still active and not connected to any extensions. The only way to clear this is to re-boot the machine.
    We have a small business license so I'm able to terminate calls but this does not disconnect the status either.
    Not really a problem but it looks like it ties up one of my 8 simultanious calls.
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello
    90 % you have a network issue
    because this means your server does not recieve buy
    is it always with external or internal calls?
  3. vincelarkin
    Aug 12, 2008
    23
    Only happens on external calls inbound
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    What is your voip phone
    is it local lan or remote phone?
  5. vincelarkin
    Aug 12, 2008
    23
    Local LAN, we are using SNOM300 handsets
  6. h2009
    h2009 Member
    Mar 15, 2008
    447
    You should be able to disconnect the calls using the management tool, which should prevent a reboot being needed.
    Can you make sure your software is up-to-date.
