Solved Linekeys in CTI-mode
Discussion in 'Windows' started by AnneD, Oct 17, 2017.
  1. AnneD
    Sep 29, 2015
    When I use the 3CX-phone in CTI-mode with a Yealink T42, I cannot select a new line to make a new call when I already have a call. There are no linekeys as in the Softphone-mode.
    How can I solve this?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,509
    468
    Hello @AnneD
    Please note that you can add line keys from the management console. Just edit the extension navigate to the BLF tab and add line keys. Reprovision the phone to apply the keys
    You can also place the person you are talking to on hold and click on new line button. This will allow you to place another call. You can switch between calls using the arrow keys
  3. AnneD
    Sep 29, 2015
    The linekeys are not visible in the application when I use it in CTI-mode.
    When I place the person on hold I can not click on the new line button, because it is not there.
  4. YiannisH_3CX
    May 10, 2016
    6,509
    468
    When the client is in CTI you need to use the IP phone to open a new line as the call is established on the IP phone. This is the way it is designed to work.
  5. AnneD
    Sep 29, 2015
    OK. Thanks.
  6. YiannisH_3CX
    May 10, 2016
    6,509
    468
    Glad i could help
