linking systems in 2 different offices
Discussion in '3CX Phone System - General' started by superrouter, Oct 25, 2007.
  1. superrouter
    Oct 25, 2007
    Is there and info on linking 2 systems in different offices?
    Thanks very much :D
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please provide more information for the existing.
    How many extensions at both office?
    What type of existing PABX in use?
    Both office using 3CX box or just one of them use 3CX?
  3. superrouter
    Oct 25, 2007
    hi Ricky
    16 extensions in the 1 office and 8 in the other. We want to move the whole system over to 3cx.
    thanks for ytour help.
  4. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    We recommend to install 2 seperate 3cx system in both office and set a pbx systemin both office first.
    then if you have installed 3cx version 4 alpa release you will see trunking option for 2 3cx system using that you can trunk both of your ofice pbx system.
    i hope this is helpful to you.
