Linksys 3102 Incoming Fax
Discussion in '3CX Phone System - General' started by comresource, Aug 27, 2009.
  1. comresource
    comresource Member
    May 22, 2009
    303
    I have been trying to get a Linksys 3102 to receive incoming faxes but have not had much luck. If I set the destination to a IP phone it rings and works fine. If I set it to 'Send fax to email' it does not work. My fax extension is 8888. What is odd is that I also have an anolog phone on the FSX port of the 3102 and if I dial 8888 from the phone I receive fax tone but it does not work from an external number. Any suggestions?
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Same here, except I have a DID pointed to it.
    214-453-0059 < It rings threw, and then disconnects, nothing in logs about anything missing, all other stuff works fine. Call 8888 internal and get proper fax tone. I have done the SIP to FAX workaround.
  3. mckey415
    Jun 27, 2007
    24
    Same problem here with DLink DVG-3004S.
    Incoming calls to extensions work fine. But when i set route incoming calls to fax extension i got no answer.
    I tried several times and once i managed to recieve fax tone. But that's all...
  4. tpinnovations
    Jul 30, 2009
    296
    I'm afraid this feature, which is one of the strongest selling points for us I might ad, is probably going to be discontinued. I have worked very hard to try to get faxing working for the last few months, I have tried multiple providers, PRIS, Patton hardware, insuring the providers pass T38 and all that jazz. No luck. It sucks, and it really needs to be addressed and promptly.
  5. ice
    ice New Member
    Jun 11, 2008
    108
    If I connected Linksys3201 directly to VoIP-provider - fax works.
    If through 3cx (without fax service) - nothing, possible it is neccesary to make separate settings for passing faxes?
