Linksys 3120 setup as ata but won't outbound call
Discussion in '3CX Phone System - General' started by Sam71, Sep 29, 2012.
  1. Sam71
    Sep 27, 2012
    43
    Hi all,
    I have setup a Linksys 3102 as an ATA to test a new install but I can't get it to call outbound either external or other call internal extensions! Inbound calls are fine.....
    The reason for testing like this is that a Linksys PAP2T will be used for a cordless phone! This is still in production...... The 3102 will be inturn used as the FXO, due to 3CX running on Hyper-V with replica (2012)
    The Cisco 504Gs are working well setup as provisioned!.
    Any ideas?
    11,283
    360
    Have you modified the internal (3102) dialplan to support the digits that you are dialling? You will probably be getting a fast busy if it does not like your digits.
    Do any calls show up in the 3CX logs? If so, what digits are they showing as being received?
  3. Sam71
    Sep 27, 2012
    43
    Have "[x*]" in dial plan.....
    Log!
    29-09-2012 17:41:05.242 Leg L:32.1[Extn] is terminated: Cause: BYE from PBX
    29-09-2012 17:41:05.200 [CM503020]: Call(C:32): Normal call termination. Call originator: Extn:105. Reason: Not found
    29-09-2012 17:41:05.200 [CM503014]: Call(C:32): No known route from Extn:105 to target: <sip:0@192.168.115.30:5060>
    29-09-2012 17:41:05.200 Call(C:32): from Extn:105 to 0 doesn't match any outbound rule. No outbound rule could be selected.
    29-09-2012 17:41:05.200 [Flow] Target endpoint for 0 can not be built!
    29-09-2012 17:41:05.199 [CM503001]: Call(C:32): Incoming call from Extn:105 to <sip:0@192.168.115.30:5060>
  4. leejor
    11,283
    360
    It looks as if 3Cx is receiving a zero and is attempting use outbound rules to route the call. What are you actually dialling?
    You can try a simple dialplan that will handle 3 digit internal numbers... [xxxS0] , then add onto that to include outside numbers.
    Here is but one link to constructing Linksys dial-plans... http://www.toao.net/108-linksys-dial-plan-tips
  5. Sam71
    Sep 27, 2012
    43
    Used (*xx|000S0<:mad:gw0>|<#0,:>xx.<:mad:gw0>|xx.) as the dial plan and all good!
