linksys 942 & multi inbound calls
Discussion in '3CX Phone System - General' started by d1rage5, Sep 4, 2008.
  1. d1rage5
    Aug 28, 2008
    Does anyone know how to set this phone to allow more then one inbound call.
    right now ext 1 is setup and i can receive a call but if another call comes in it goes to voicemail.
    I i am on the one call and place the call on hold i can make a call to another ext and outside line.
    the ext2, ext3, ext4 are all enabled but the use a different port like 5061, 5062 and 5063.
    i tried setting the port on two extensions to the same port 5060 to test but that was a no go.
  2. d1rage5
    Aug 28, 2008
    fixed my own problem...
    After more testing and test and testing. I thought i would take a look bacl at the setting on 3cx under the extensions.
    Destination Unreachable / Forwarding <<<
    then Phone Busy
    set the first setting Busy Detection to use phone and NOT use PBX stats
    Thats it workie workie now.
