Linksys 962 and 3cx few questions..NEWBIE!!
Discussion in '3CX Phone System - General' started by cjelsa, Nov 13, 2008.
  1. cjelsa
    Nov 13, 2008
    6
    Dear all,
    I have just purchased the 3cx system small business edition and (will) have 5 linksys 962 connected. I have a few questions though:
    - I auto provisioned the phones and now all 6 bfl show the extension number. If I am having a phone call on this extension though, no other calls come through. How can I use all other lines and have more calls, incoming AND outgoing?
    - how do I provision the phonebook? I purchased the 3cx system because it has auto provisioning.....
    - how do I provision the BFL buttons?
    If someone knows the solutions for above, I would appreciate it....
    Kind Regards,
    Chris
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    1-You have to create 6 accounts in 3CX and your spa962
    2-You do not have BLF in your SPA962 IF you need BLF you have to buy SPA932 (32BLF)
    I did not try it yet
    3-I do not have phone book so I can not help you in this point
  3. cjelsa
    Nov 13, 2008
    6
    Thank you for you answer.
    As I understand the 6 BSF on the 962 are the same as all of them on the 932.
    I still don't know how to achieve call waiting in the current setupI have. How can I arrange for this? Of the 6 registered extensions (all the same) I basically only use the first one.
    Are there any answers on phonebook provisioning?
    Thanks in advance!
    Regards,
    Chris
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    no it's not blf
    this for account choice
    you have to create 6 extensions in 3CX
    the configure 6 accounts in spa3102
    to open call waiting in each extension
    you have change use pbx status to use phone status in extension settings /forward rules
  5. cjelsa
    Nov 13, 2008
    6
    Dear galal202,
    I don't understand which settings I need to change to activate call waiting on all extensions and phones.
    I have 5 Linksys 962's connected to 3cx ver 6.1.0 small business version.
    Ideally I would have 5 extensions for 5 phones and would be able to use multiple internal as well as external (VoIP provider has unlimited simultaneus lines/calls) lines. How can I achieve this with what settings?
    Thanks in advance for the reply.
    Regards,
    Chris
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    each spa962 has 6 lines
    each line has 2 calls
    in the 3CX server settings /extension settings / forward rules
    you have to set forward rules and ring groups to get second and third ...etc calls
