Linksys IP Phone SPA942
Discussion in '3CX Phone System - General' started by Fusspils, Apr 29, 2009.
  1. Fusspils
    Apr 29, 2009
    Hi all,
    First of all I am really impressed with the 3CX product. The next step for me before buying the system is to get our Linksys SPA 942 phones hooked up to our 3CX server from the "outside."
    Everything works with these IP phones internally in our test environment and also the software phone works really well from the internet calling into our network so I am guessing that all routing etc is working well. Can anyone point me to a setup guide or tutorial so I can get the Linksys systems working externally? I have tried all sorts of combo´s with the proxy settings etc all with no success.
    Any help would be greatly appreciated as I really want to get the full product up and running ASAP
    Andy
  2. sipero123
    Nov 24, 2008
    94
    With the Enterprise version rather than the FREE version you would be able to use auto-provisioning of your SPA942 phones.
    You'll find the Voip Nugget and this url http://www.3cx.com/docs/ and this file at http://www.3cx.com/sip-phones/
    Hope these help.
    Jonathan Hamon
  3. ciscotech2007
    Jan 27, 2009
    94
    Your referring to the remote external extension option.
    This means your phone connects to 3CX as a 3CX extension but is not on your local network where the 3CX server is at.
    From your remote network to your 3CX network, all your firewalls and routers must support STATIC NOT mapping.
  4. Fusspils
    Apr 29, 2009
    Thanks for the replies,
    sipero123 - I will give these configurations a try on Monday and post the results
    ciscotech2007 - Yes I want to send some Linksys phones pre-setup to a branch office so they can just plug and play. The softphone works through our firewalls/routers etc so the phones should right?
  5. Fusspils
    Apr 29, 2009
    I gave the nugget a try but still have errors, here are the steps that I performed.
    Factory reset of the phone.
    Selected "Admin" and "Advanced" options
    SIP TAB
    STUN enable --> Yes
    Server --> stun.3cx.com
    EXT 1 TAB
    Proxy --> Public IP of our 3CX Server
    Register expires --> 300
    Display name --> Username
    User ID --> Extention number of user
    Pass --> users password
    User auth ID --> Yes
    auth ID --> Extendion number of user
    Dial plan --> [x*].
    Am I missing anything? As I said in a previous post the soft phone works fine so I am guessing that all port routing etc is good. Any help would be great!
  6. ciscotech2007
    Jan 27, 2009
    94
    Here's the setup for INTERNAL extensions on SPA units;
    http://www.3cx.com/sip-phones/linksys-SPA-962.html
    Complete this first to ensure your 3CX system is fully operational INBOUND AND OUTBOUND. And this also checks the phones to make sure they function on the 3CX system.
    Then check out the remote extension voip nugget listed above. Please post your results.
  7. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    SIP Tab:
    You'll also want:
    Substitute VIA Addr: Yes
    Send Resp To Src Port: Yes
    STUN Enable: Yes
    NAT Keep Alive Intvl: 15 (find out how long your router leaves sessions open for, and choose a lower number - 15 is agressively low, but works!).
    Other options can be no.
    Ext 1:
    NAT Mapping Enable: Yes
    NAT Keep Alive Enable: Yes, or you'll need to set up static port forwards in your remote site routers.
    I also have
    Use Outbound Proxy: Yes
    Use OB Proxy In Dialog: Yes
    OB proxy is set to the 3cx server (I have a static IP and a dns entry, so the phones have the DNS name, rather than the IP).
  8. dpuckett
    May 14, 2009
    I have been trying to get this fully working but have not had much luck. Here is my setup.
    1. 3CX behind a NAT on 192.168.3.112
    2. Setup 2 phones on LAN..one softphone and 1 SPA941. All works
    3. Configured Firewall as needed and the firewall check works.
    3. Configured SIP client on my Palm Centro and am able to register to 3CX and all works fine (Treo is not behind a NAT)
    4. Moved SPA941 to another network behind a NAT and followed Voip Nugget for external connections adding STUN and changing Proxy to External FQDN of 3CX connction. Phone Registers fine but it shows up on Activity log as 102@192.168.5.104 (The Phones Internal IP address). I get dial tone but any calls fail with busy signal.
    5. If I Make the additional NAT/Outbound proxy settings as suggested by BJReplay the phone no longer registers.
    Any help in this would be greatly appreciated.
  9. dpuckett
    May 14, 2009
    [SOLVED]
    I swapped out the NAT device on the phone side from pfsense (FreeBSD based) to a snapgear (linux based) and it started working with the changes suggested by BJReplay.
