Linksys PAP2T configuration
Discussion in '3CX Phone System - General' started by rodneyeid, Aug 22, 2007.
  1. rodneyeid
    Aug 8, 2007
    18
    can you help me please configure the linksys PAP2T to use with my 3cx server.
    i am using web configuration window.
  2. tab
    tab
    Aug 10, 2007
    85
    #2 tab, Aug 22, 2007
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I have two PAP2s working like a charm on my network. Give me a bit of time and I will add links to this post that will give you a copy of my setup.
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  5. VictorN
    Jun 20, 2007
    30
    I have an ATA Linksys and works very well with 3CX.
  6. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Just installed one and its working, but there is a delay before 3CX and starts dialing the number your calling. I was using a Grandstream 386 and it had a few seconds delay but this delay is about 2-3 times as long. Which setting in the PAP2 do I tweak to speed this up?
    Thanks!
  7. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Usually pressing the key # after dialing the number speeds ups things...
    Cheers
  8. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    It seems the speed depends on who I'm calling. If I call a AT&T cell phone, it takes a long time to connect, but dialing others on land lines it connects quickly. When I was doing my testing I was calling my AT&T cell phone ;-)
    Thanks!
  9. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    In other forums I found issues with setting up a 10 digit dial plan properly. I added the line below to my dial plan and I no longer have that long delay. Turn out there was a 11 digit dial plan in the default PAP2 dial plan and when I called a local (10 digit) number, it was waiting for me to put in that last digit and then finally timing out. The line below fixes this. Not sure how it works but it does.
    [2-9]xx[2-9]xxxxxxS0
  10. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Its the "S0" that does it, instructs the PAP2 to process immediately when the preceeding sequence is met.
  11. Seth Thompson
    Dec 19, 2016
    webguys, Could you please post your whole dial plan please, I'm having trouble with a long silence before it calls.
    Thanks!
