Linksys PAP2T
Discussion in '3CX Phone System - General' started by wlt7913c, Feb 8, 2013.
  1. wlt7913c
    Jul 11, 2010
    I am using a Linksys PAP2T device as an extension. I have created an extension and successfully registered Line 2 and can make and receive calls. The problem I have is when I go to create another extension I cannot use the same device because of the MAC address. So how do I register the other line as an extension?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    PAP2T is ATA right? You can normally configured two extension on that device, if you put mac address of PAP2T under the extension settings remove it, you dont need to put mac address, you are not doing provisioning via 3cx in this case
  3. wlt7913c
    Jul 11, 2010
    Well it won't let me remove that information, so I will delete the extension, and not provide provisioning information and see what happens... Yep that did the trick, complete brain fart on my end regarding the provisioning. thanks
