linksys password
Discussion in '3CX Phone System - General' started by mylove4life, Oct 24, 2010.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi all, is there anyway to get a admin password out of a Linksys SPA921 or at least reset it? thanks
    10,582
    249
    Pick up handset, press menu button, dial 14, press "OK" when asked if you want to reset. As far as I know, there is no way to recover an Admin password, next time you should use something you will remember.
  3. mylove4life
    Jan 7, 2010
    165
    I bought used on a chance I could reset it. If not I lost 30 bucks...
  4. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    can you get to the setup button on it? if so there is a factory reset softkey. Will it allow it without the admin password?
  5. mylove4life
    Jan 7, 2010
    165
    How do I see if there is a softkey?
  6. abc123
    Nov 9, 2009
    712
    press the setup button on the 941 phone.
    You see a list of menus.
    Scroll down using the big cursor and it should be number 14
    Press select
  7. mylove4life
    Jan 7, 2010
    165
    It has that, but what good is it when you need the admin password to reset it?
