Linksys SPA-3102 Call Termination problem
Discussion in '3CX Phone System - General' started by joshhough, Feb 2, 2012.
  1. joshhough
    Feb 22, 2011
    72
    Hi There,
    I'm using a Linksys SPA-3102 as a PSTN interface, and seem to have a bit of an issue.... Calls aren't terminating - i'm manually having to disconnect the call from the 3CX Managment console in order for another call to come through - does anyone know if theres an option that i've just forgotten to tick/change?
    Thanks,
    Josh
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    You may need to consult the Admin guide of SPA-3102 (available on Internet) to understand different criteria for disconnecting calls. Among these are:
    - busy tone (varies by country / provider)
    - CPC
    - polarity reversal
    - long silence detection (PSTN and/or VoIP)
    Also important is the resistance of PSTN port (default 600 Ohms), try setting according your country recommended settings or to 'Global'. Not so simple, you need to experiment.
    Regards
  3. joshhough
    Feb 22, 2011
    72
    I ended up using this - http://james-lloyd.com/wiki/SPA3102_UK_Settings#Disconnect_Detection really really useful!
    Got it working instantally.
    Thanks,
    Josh
