LinkSys SPA-3102 with 3CX 3.1
Discussion in '3CX Phone System - General' started by SMX, Sep 9, 2007.
  1. SMX
    SMX
    Jul 20, 2007
    6
    I have difficulty to configure Linksys SPA3102, 1x FXO and 1x FXS.
    The problem was FXO port on the SPA3102 cannot receive call and also from the softphone (X-Lite) and also from the FXS Port in the SPA3102 cannot dial out. In the 3CX server status informs as Call (3) 404 Not Found and then follow by Call (3) Rejected. What is 404 Not Found Mean? In the PC that 3CX Installed the firewall was inactive. All the SPA3102 configuration was use the guidance from 3CX Website.
    If I try to use FXO port as extension, I can dial out use the extension. But I want to use the SPA3102 as PSTN Line. Please help ... :-(
    Thank you.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    HI,
    Please post the console log here for us to investigate your problem.
  3. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  4. SMX
    SMX
    Jul 20, 2007
    6
    The logs:
    Time: 16:31:37.666
    Function: CallConf;; Rejected; Not Found
    Message: [CM102005] Call(3) is Rejected; Not Found
    Time: 16:31:37.666
    Function: StratlnOut;; on Cancel
    Message: [CM104008] Call(3); Call from Ext.1001 to 3550368 terminated; cause; 404 Not Found; from IP:192.168.1.254
    Time: 16:31:37.525
    Fuction: CallConf;;onlncoming
    Message: [CM103002] Call(3); Incoming call from 1001 (Ext.1001) to sip:93550368@192.168.1.22
    Note:
    my 3CX IP dan my softphone at IP 192.168.1.22
    Linksys SPA3102 at IP 192.168.1.254
    Thank you.
    [/url][/u][/quote]
  5. tab
    tab
    Aug 10, 2007
    85
    Are the calls between extensions ok? Is the configured SPA PSTN line registered at the 3CX line status?
  6. tab
    tab
    Aug 10, 2007
    85
    "Message: [CM103002] Call(3); Incoming call from 1001 (Ext.1001) to sip:93550368@192.168.1.22"
    I think your applied dial plan in spa is not correct.
    tab
  7. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Please go over the configuration guide which is available on our website.
    Check things like dialplan if its configured correctly. Check if lines are registered inside line status. do you not receive calls either? you can't make calls or both?
    Regards
  8. SMX
    SMX
    Jul 20, 2007
    6
    Internal call beetween SPA3102 FXS port to X-Lite Softphone is OK no Problem.
    But when I'm trying to call out from X-Lite or from the FXS Port the call was rejected.
    I'm not set any dial plan in the SPA3102, just dialplan 8 as describe in the guidance from 3CX. All lines registered on the 3CX server. I cannot receve call from PSTN. The SP3102 didn't receive call.
  9. Costas3CX
    Jan 23, 2007
    217
    Check that the port inside 3cx configured for that pstn line, and the port configured inside the pstn line page in the webconfig of the SPA 3102 are the same.
    And double check your otubound rules that you have a transform mask (r)
    Regards
