Linksys SPA-3102 with dynamic IP
Discussion in '3CX Phone System - General' started by dnwklin, Sep 23, 2009.
  1. dnwklin
    Feb 2, 2009
    10
    I saw the wiki page instruction me to give the gateway a static IP.
    I would like to know will that device work with dynamic IP as I am not able to assign an static IP to that device.
    The communication between the gateway and the server is over the internet.
    10,864
    303
    You would have to give the device a fixed private IP behind a router that is using a dynamic DNS service, like DYNDNS.COM. With a gateway 3Cx wants the IP of the device, assuming it is on the same LAN, so you need to put in the dynamic dns info there. Many routers have a place to make use of a service such as that, then you don't have to have a fixed public IP. You may run into some problems if you are trying to bring a remote trunk into the 3CX. I have tried, but not too hard (just not enough time or a pressing demand to spend time troubleshooting it right now). Managed to get it (sort of) working to a point, maybe, sometimes. It has issues.
    It should work, in theory.
    Good luck, post back if you succeed.
  3. dnwklin
    Feb 2, 2009
    10
    Thanks for help. I will try
