Linksys SPA 8000
Discussion in '3CX Phone System - General' started by Nebula, Jun 22, 2008.
  1. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    May sound like a dumb question and I know it is not on the approved hardware list but does anyone see why the Linksys SPA 8000 should not work with 3Cx to provide multiple (8) analogue extensions? Better still has anyone used it?
  2. mickp
    Jun 9, 2008
    72
    I'm using one in a system that we're provisioning at the moment as a replacement for our panasonic pabx system. Works great so far though we've not had it in production yet so may discover further issues down the track. Setup looks pretty much the same as for an spa3000 if that helps.
    Mick.
  3. Henk
    Henk Member
    Nov 13, 2007
    250
    Like Mick said should work just fine.
    H.
  4. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Thanks guys.
    Mick, I would appreciate an update when it's all live especially if you test analogue fax through it.
    Regards
