Linksys SPA3000
Discussion in '3CX Phone System - General' started by justin, Jul 8, 2008.
  1. justin
    Feb 20, 2008
    79
    Before I purchase this item, I understand that Sipura was purchased by Linksys, so does that mean the Linksys SPA3000 will work as a PSTN adaptor with 3CX so that I can make outbound calls on the normal PSTN line?
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    The SPA3102 can be used to make outbound call to a normal PSTN using 3CX and SIP phones.
    Linksys is bought by CISCO, it is all owned by CISCO now a days.
    Any troubles let me know.
    H.
  3. justin
    Feb 20, 2008
    79
    Yes, but what about the Linksys SPA3000 (3CX has PSTN option for Sipura SPA3000)? I was wondering if it would work or if they are different?
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    The option in 3CX is to register the SPA3000.
    The difference between the spa3000 and spa3102 is that the 3102 is newer (replaces the 3000), has a router and you can configure 4 VSP's (which in this case if you use 3cx is not needed, unless you want to have the spa route calls based upon cheapest plan).
    From a 3cx point of view there is no difference, both function the same.
    H.
  5. justin
    Feb 20, 2008
    79
    My query is: 3cx specifies "Sipura SPA3000" and "Linksys SPA3102" however, upon looking at e-auction sites there is a "Linksys SPA3000" which I presume is the same, I just didn't want to go spending $60 if it wouldnt interface with 3cx the same.
  6. Henk
    Henk Member
    Nov 13, 2007
    250
    it will interface with 3CX, the difference is as I outlined above :).
    SPA3000 is just the older model, but will work fine (if configured correct) with 3CX and will work as ATA.
    H.
  7. justin
    Feb 20, 2008
    79
    After all this concern I ended up picking up a SPA3102 cause I think the seller listed it as the wrong price seeing as how it was cheaper then I could pick up a SPA3000 for and all the rest of their SPA3102's were $30 more :)
    [/Happyness]
  8. Henk
    Henk Member
    Nov 13, 2007
    250
    :) better to have new gear.
    Wise choice, I been using one for a few yrs now. Very happy with it, set and forget type scenario.
    Keep in mind they do get hot, so keep it ventilated. (mind you it is not an egg cooker).
    H.
  9. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    I have one plugged into a remote lan across a VPN, it receives calls fine from the local pstn at the remote site, i have registered it as a gateway, however outbound calls rather than go to the destination are received with a standard UK BT message about BT.
    Here is a screenshot. I created a new PSTN Gateway using the SPA 3102 template since the 3000 template does not appear. the line is 10005. See below:
    If I call the PSTN number the device is plugged into, my default extension rings fine as expected. However, any outbound calls that route via it do not go anywhere but you hear the BT message as though you'd dialled a generic BT support number.
    Any ideas ?
  10. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Right I done a hard reset to cure the calling out from the remote extension via the SPA 3000 over the analog, now that is working, however the inbound to the analog line doesn't ring the extension as specified in the PSTN gateway! This was working prior to the hard reset :lol:
  11. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Right got it working now.
    Outbound works fine.
    Inbound works, but with significant lag from when the number is dialled. Long delay before ringing. I'm calling it a night, the main thing is it's working. Any ideas on the PSTN -> VOIP ringing lag ?
    Cheers, Lewis
  12. leejor
    10,563
    245
    I've got both the 3000 and 3102 working on the 3CX with no issues, there is a setting (in seconds) before a PSTN call will ring through to VoIP (don't have mine in front of me to look at the exact name of the setting right now). In North America, to be able to get caller ID to pass through to the 3CX you can't set it lower than 3 seconds.
  13. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    ok, thanks I will trawl through the settings tonight and locate it, obviously the hard reset has reset the value to some default that is long.
  14. leejor
    10,563
    245
    Had a quick look though the manual (5-64), under the PSTN tab, PSTN-to-VoIP Gateway Setup, PSTN Answer Delay, the factory default is 16 seconds, change that to 3 seconds, or even lower if you don't need to wait for BellCore type caller ID.
  15. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Cheers Leejor, saved me a lot of time there.
  16. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Implemented it this evening and works a dream. I set it to zero, significant improvement, there is still a slight lag on ring, say 2-3 rings, and when the call is terminated, it rings for an extra 2-3 rings. Not a significant issue, more an observation, although I am happy with this now. Thanks again. Lewis
  17. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Glad it worked. Now you can do it all over again when v8 gets released. :lol:
  18. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    :roll:
    when is v8 expected to be released ? any idea ?
  19. tpinnovations
    Jul 30, 2009
    296
    When its out. :mrgreen:
  20. Henk
    Henk Member
    Nov 13, 2007
    250
    Would not see why that is.
