LInksys SPA3102 Gateway Help Needed - InBound Calls
Discussion in '3CX Phone System - General' started by sinboo50, Dec 30, 2009.
  1. sinboo50
    Feb 28, 2009
    25
    I am not able to ring inbound calls with the SPA3102. The server log is attached:
    Outbound calls work great and Line is Registered in 3CX.
    Thanks in advance,
    Bruce
    11,086
    325
    I can see two lines and the top edge of a third and none of it means a thing, to me. Did you set the 3102 up according to the 3Cx info (leaving the * out of the caller Id field)? There are many, many, many options in the 3102, and the inbound call failure can be caused by the wrong info being in just one of them. Does the 3CX log show an incoming call attempt? Had the 3102 been used elsewhere, in other words did you provision it from a factory reset or just modify some of the settings after it was used in a previous installation?
  3. sinboo50
    Feb 28, 2009
    25
    All is setup according to the config. guide...
    I did remove the * from the CID field and it works so guess that was it.
    Thanks,
    Bruce
  4. leejor
    11,086
    325
    That was discovered by a member through trial and error a little while ago, not sure why they (3CX) haven't changed the set-up guide to reflect the error.
  5. sinboo50
    Feb 28, 2009
    25
    Agreed. Seems like it would be a big deal.
    Now I am trying to solve the CID issue ... have tried to delay the PSTN call by 5 sec. but then it does not ring. Everything else seems to be OK including the PSTN CID For VoIP CID: YES
    If you know the answer to that one i would very much appreciate it.
    Cheers,
    Bruce
  6. open7
    Jan 7, 2010
    30
    You mention that you should remove the * in the VoIP Caller ID Pattern field, If I do that the CID shows the Subscriber Info Display Name "SPA-3102". If I have the * there the CID shows the correct CID. Why did they determine that it should be removed?
    Don
  7. leejor
    11,086
    325
    That was discovered by a board member a number of months back (do a search on 3102 posts). I, myself , have never put the * in the field and have no problem with caller ID. The "SPA3102", or what ever name you've called the gateway will generally show up if there is no name/caller ID info available from the PSTN, either because you don't subscribe or the 3102 is not set to wait at least 3 seconds before sending the call info to 3CX (Bellcore type caller ID).
  8. open7
    Jan 7, 2010
    30
    But what is strange is that if I put the * there and I have zero seconds to transfer the call to 3CX, I get the CID. But, if I remove the * I get the "SPA3102" default. Sort of backwards.
    Don
  9. leejor
    11,086
    325
    That's an odd one. Caller Id (Bellcore type) is sent between the first and second ring, Under normal circumstances, if you don't wait at least 3 seconds for the 3102 to collect the name/number then only the default name that you datafilled, will be passed on to the 3CX.
