linksys SPA3102 Not Response
Discussion in '3CX Phone System - General' started by George Georgiou, Aug 2, 2007.
  1. George Georgiou
    Jul 21, 2007
    22
    The Linksys SPA3102 PSTN LINE Status: Registered.
    I can not Make Call outsite or insite, I follow all the proceture on the forum instractions.
    I am using ISDN NT for FXO analoge
    any help
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please provide the system log.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If you using ISDN line. The FXO analog gateway device should be not support. It should be use ISDN BRI or PRI gateway. It will depend the telco provided which type.
    Just let you know that your Linksys SPA3102 already registered the 3CX box. And it can be allow to form a SIP call to PBX.
