- Joined
- Apr 21, 2009
- Messages
- 129
- Reaction score
- 0
I am in a flap
I have had my 3CX working wonderfully for a number of years with a Grandstream FXO: GWX4104. The Gradstream failed and I needed a new device, but with only two PSTN lines I thought that another GWX was a bit over kill. I subsequently bought 2 x linksys spa3102 devices, one for each and have upgraded my 3CX from version 9 to 12...
I just can't make this work. In or outbound. The two Lynxisys devices work when the analogue phone is connected directly, but not as an FXO. I have followed everything I have found on line. Can anyone help, please. Please see below for sys log for an outbound call. The addition of a 4 is to force an outbound call via the FXO instead of the SIP gateway/service provider. This is stripped
Inbound the call does not even show in the logs... and yes the devices are registered.
Code:
23-Nov-2013 11:07:56.625 L:47.1[Extn] got Terminated Recv Req CANCEL from 192.168.1.90:5060 tid=798c9140c2c196ab1ca32280f60eff11 Call-ID=704268022@192_168_1_90:
CANCEL sip:[email protected];user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.1.90:5060;branch=z9hG4bK798c9140c2c196ab1ca32280f60eff11;rport=5060
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected];user=phone>
From: "Baroni Limited"<sip:[email protected]>;tag=2294670366
Call-ID: 704268022@192_168_1_90
CSeq: 3 CANCEL
Proxy-Authorization: Digest username="200", realm="3CXPhoneSystem", algorithm=MD5, uri="sip:[email protected];user=phone", nonce="414d535c08a11d6717:9207c2074ab942b3fd076ac4f35e9abc", response="cf81298bb9a8ef4fdd170651f4bdd233"
User-Agent: N300 IP/42.075.00.000.000
Content-Length: 0
23-Nov-2013 11:07:56.625 Terminated from "Baroni Limited"<sip:[email protected]>;tag=2294670366 to <sip:[email protected];user=phone>;tag=fe23ec71; reason: RemoteBye
23-Nov-2013 11:07:56.625 L:47.1[Extn] Sending: OnSendResp Send 487/INVITE from 0.0.0.0:0 tid=798c9140c2c196ab1ca32280f60eff11 Call-ID=704268022@192_168_1_90:
SIP/2.0 487 Request Terminated
To: <sip:[email protected];user=phone>;tag=fe23ec71
CSeq: 3 INVITE
Content-Length: 0
23-Nov-2013 11:07:56.625 SendMsg from <sip:[email protected];user=phone>;tag=fe23ec71 to "Baroni Limited"<sip:[email protected]>;tag=2294670366
23-Nov-2013 11:07:56.625 L:47.1[Extn] Sending: OnSendResp Send 200/CANCEL from 0.0.0.0:0 tid=798c9140c2c196ab1ca32280f60eff11 Call-ID=704268022@192_168_1_90:
SIP/2.0 200 OK
Contact: <sip:[email protected];user=phone>
CSeq: 3 CANCEL
Content-Length: 0
23-Nov-2013 11:07:52.345 L:47.2[Line:10001>>02086689100]: Terminating targets, reason: SIP ;cause=408 ;text="Request Timeout"
23-Nov-2013 11:07:52.345 Leg L:47.2[Line:10001>>02086689100] is terminated: Cause: 408 Request Timeout/INVITE from local
23-Nov-2013 11:07:52.345 L:47.2[Line:10001>>02086689100] got Terminated Recv 408/INVITE from 0.0.0.0:0 tid=470ece4f0b13026f Call-ID=MDIyN2RjZjc5MTRkNmNjZDM5MTQ5YjZlMjg1MTlhZTQ.:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP 192.168.1.51:5060;branch=z9hG4bK-d8754z-470ece4f0b13026f-1---d8754z-;rport
To: <sip:[email protected]:5062>;tag=17486b5c
From: "Baroni Limited"<sip:[email protected]:5060>;tag=dd4c2032
Call-ID: MDIyN2RjZjc5MTRkNmNjZDM5MTQ5YjZlMjg1MTlhZTQ.
CSeq: 1 INVITE
Content-Length: 0
23-Nov-2013 11:07:52.345 Terminated from <sip:[email protected]:5062>;tag=17486b5c to "Baroni Limited"<sip:[email protected]:5060>;tag=dd4c2032; reason: Error
23-Nov-2013 11:07:52.345 ~Target=PSTNline:02086689100@(Ln.10001@OFFICE)
23-Nov-2013 11:07:52.345 [CM503025]: Call(C:47): Calling T:Line:10005>>02086689100@[Dev:sip:[email protected]:5060] for L:47.1[Extn]
23-Nov-2013 11:07:52.344 Route to L:47.3[Line:10005>>02086689100] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=c96f1d2adc69cd6a Call-ID=ZTkyMTU5MmQ4NjJlZjQ4NDZjMWNjOTIxMTliYjdlYmI.:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-c96f1d2adc69cd6a-1---d8754z-;rport
Max-Forwards: 70
To: <sip:[email protected]:5060>
From: "Baroni Limited"<sip:[email protected]:5060>;tag=ed69824b
Call-ID: ZTkyMTU5MmQ4NjJlZjQ4NDZjMWNjOTIxMTliYjdlYmI.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
Content-Length: 279
v=0
o=3cxPS 5351931904 123346092033 IN IP4 82.14.176.51
s=3cxPS Audio call
c=IN IP4 82.14.176.51
t=0 0
m=audio 9044 RTP/AVP 0 8 3 99 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:99 SPEEX/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
23-Nov-2013 11:07:52.344 Dev(1):[sip:[email protected]:5060 / 844231085]: PBX contact is resolved to public IP: <sip:[email protected]:5060>
23-Nov-2013 11:07:52.171 Outbound URI is used: sip:77.240.48.201:5065
23-Nov-2013 11:07:52.167 Added leg L:47.3[Line:10005>>02086689100]
23-Nov-2013 11:07:52.167 ~Route=Dev:sip:[email protected]:5060
23-Nov-2013 11:07:52.167 Call to T:Line:10001>>02086689100@[Dev:sip:[email protected]:5060] from L:47.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
23-Nov-2013 11:07:52.163 L:47.2[Line:10001>>02086689100] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=470ece4f0b13026f Call-ID=MDIyN2RjZjc5MTRkNmNjZDM5MTQ5YjZlMjg1MTlhZTQ.:
CSeq: 1 INVITE
Content-Length: 0
23-Nov-2013 11:07:52.157 [CM503003]: Call(C:47): Call to <sip:[email protected]:5062> has failed; Cause: 408 Request Timeout/INVITE from local
23-Nov-2013 11:07:52.155 Session 95886 has failed in leg L:47.2[Line:10001>>02086689100] ; Cause: 408 Request Timeout/INVITE from local
23-Nov-2013 11:07:52.150 Failure from <sip:[email protected]:5062>;tag=17486b5c to "Baroni Limited"<sip:[email protected]:5060>;tag=dd4c2032
23-Nov-2013 11:07:40.886 Currently active calls - 1: [47]
23-Nov-2013 11:07:20.022 [CM503025]: Call(C:47): Calling T:Line:10001>>02086689100@[Dev:sip:[email protected]:5060] for L:47.1[Extn]
23-Nov-2013 11:07:20.022 Route to L:47.2[Line:10001>>02086689100] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=7609461399746f36 Call-ID=MDIyN2RjZjc5MTRkNmNjZDM5MTQ5YjZlMjg1MTlhZTQ.:
INVITE sip:[email protected]:5062 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-7609461399746f36-1---d8754z-;rport
Max-Forwards: 70
CSeq: 1 INVITE
Supported: replaces
Content-Length: 357
v=0
o=3cxPS 441525993472 356364845057 IN IP4 192.168.1.51
s=3cxPS Audio call
c=IN IP4 192.168.1.51
t=0 0
m=audio 7170 RTP/AVP 0 8 3 13 9 110 99 101
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=rtpmap:9 G722/8000
a=rtpmap:110 iLBC/8000
a=sendrecv
23-Nov-2013 11:07:19.996 Outbound URI is used: sip:[email protected]:5060
23-Nov-2013 11:07:19.983 Added leg L:47.2[Line:10001>>02086689100]
23-Nov-2013 11:07:19.927 [Flow] Call(C:47): making call from L:47.1[Extn] to T:Line:10002>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 [CM503027]: Call(C:47): From: Extn:200 ("Baroni Limited" <sip:[email protected]:5060>) to T:Line:10002>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 [CM503004]: Call(C:47): Route 3: from L:47.1[Extn] to T:Line:10002>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 Line limit check: Current # of calls for line Lc:10002(@HOME[<sip:[email protected]:5060>]) is 0; limit is 1
23-Nov-2013 11:07:19.927 [Flow] Call(C:47): making call from L:47.1[Extn] to T:Line:10005>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 [CM503027]: Call(C:47): From: Extn:200 ("Baroni Limited" <sip:[email protected]:5060>) to T:Line:10005>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 [CM503004]: Call(C:47): Route 2: from L:47.1[Extn] to T:Line:10005>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 Line limit check: Current # of calls for line Lc:10005(@VoIPTalk[<sip:[email protected]:5060>]) is 0; limit is 2
23-Nov-2013 11:07:19.927 [Flow] Call(C:47): making call from L:47.1[Extn] to T:Line:10001>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 [CM503027]: Call(C:47): From: Extn:200 ("Baroni Limited" <sip:[email protected]:5060>) to T:Line:10001>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 [CM503004]: Call(C:47): Route 1: from L:47.1[Extn] to T:Line:10001>>02086689100@[Dev:sip:[email protected]:5060]
23-Nov-2013 11:07:19.927 Line limit check: Current # of calls for line Lc:10001(@OFFICE[<sip:[email protected]:5060>]) is 0; limit is 1
23-Nov-2013 11:07:19.927 Call(C:47): Call from Extn:200 to 402086689100 matches outbound rule 'PSTN Baroni'
23-Nov-2013 11:07:19.927 [Flow] Call(C:47): has built target endpoint: Out#:>>Rule{PSTN Baroni}>>402086689100 for call from L:47.1[Extn]
23-Nov-2013 11:07:19.927 [Flow] Target endpoint for 402086689100 is Out#:>>Rule{PSTN Baroni}>>402086689100
23-Nov-2013 11:07:19.927 Selected prefix: 4
23-Nov-2013 11:07:19.927 Looking for outbound rule: dialed = [402086689100], processed: [402086689100]; from-ext:
23-Nov-2013 11:07:19.927 [Flow] Building target endpoint to 402086689100 from "Baroni Limited" <sip:[email protected]:5060>
23-Nov-2013 11:07:19.927 [CM503010]: Call(C:47): Making route(s) from Extn:200 to <sip:[email protected]:5060>
23-Nov-2013 11:07:19.927 Remote SDP is set for leg L:47.1[Extn]
23-Nov-2013 11:07:19.927 OnOffer from "Baroni Limited"<sip:[email protected]>;tag=2294670366
23-Nov-2013 11:07:19.926 [CM505001]: Endpoint Extn:200: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [N300 IP/42.075.00.000.000] PBX contact: [sip:[email protected]:5060]
23-Nov-2013 11:07:19.905 Inbound DID: ''; Phonebook Name: ''
23-Nov-2013 11:07:19.905 [CM500002]: Call(C:47): Info on incoming INVITE from Extn:200:
Invite-IN Recv Req INVITE from 192.168.1.90:5060 tid=798c9140c2c196ab1ca32280f60eff11 Call-ID=704268022@192_168_1_90:
INVITE sip:[email protected];user=phone SIP/2.0
Max-Forwards: 70
CSeq: 3 INVITE
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, REFER, SUBSCRIBE, NOTIFY
Proxy-Authorization: Digest username="200",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:[email protected];user=phone",nonce="414d535c08a11d6717:9207c2074ab942b3fd076ac4f35e9abc",response="371787970a59a02275636051f2acc0d6"
Supported: replaces
Allow-Events: message-summary, refer, ua-profile, talk
Content-Length: 381
v=0
o=200 5006 197 IN IP4 192.168.1.90
s=Mapping
c=IN IP4 192.168.1.90
t=0 0
m=audio 5006 RTP/AVP 9 8 0 96 97 2 18 101
a=rtpmap:96 G726-32/8000
a=rtpmap:97 AAL2-G726-32/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
23-Nov-2013 11:07:19.905 [CM503001]: Call(C:47): Incoming call from Extn:200 to <sip:[email protected]:5060>
23-Nov-2013 11:07:19.868 Outbound URI is used: sip:[email protected]:5060
23-Nov-2013 11:07:19.868 IncomingCall: C:47 from <sip:[email protected]:5060> to <sip:[email protected]:5060>
23-Nov-2013 11:07:19.868 Added leg L:C:47.1[No endpoint yet]
23-Nov-2013 11:07:19.865 UasSession 95857 started
23-Nov-2013 11:07:19.865 Call from "Baroni Limited"<sip:[email protected]>;tag=2294670366 to <sip:[email protected];user=phone>;tag=fe23ec71
23-Nov-2013 11:07:10.769 Currently active calls [none]
