Linksys SPA400??
Discussion in '3CX Phone System - General' started by kaskiland, Sep 14, 2010.
  1. kaskiland
    Sep 13, 2010
    8
    I have in the company the Linksys SPA400 used with Asterisk
    We bought this new software and license (3CX), and I would like to know how to configure the PBX to route calls to mobile in SPA400
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
  3. leejor
    10,750
    285
    Here is a link to a previous post about the SPA400... http://www.3cx.com/forums/someone-has-tested-spa400-on-3cx-995-15.html
  4. kaskiland
    Sep 13, 2010
    8
    I want to set is that when a person calls to a mobile (6xxxxxx) that call routed by PBX to Linksys SPA400 phones calls to go out there
  5. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Set an outbound rule with a ddi mask starting with 6 (or the full prefix if it helps) and the number length of the mobile number and set it to go out through the spa400
    Make sure that outbound rule is near or at the top of the list as rules are applied in top down order
  6. kaskiland
    Sep 13, 2010
    8
    Ok thanks i known this steps
    But I want to know is, adding the SPA400 gateway control unit only gives me the option of SPA-3102New, if I put that model worked well in my SPA400?
