linksys spa921
Discussion in '3CX Phone System - General' started by techworx, Jul 26, 2008.
  1. techworx
    Jul 22, 2008
    17
    when i pick up the phone ,if i dont dial in 1 sec it goes to an engaged tone,is there a setting in the linksys config to make this a bit longer?
  2. ess
    ess New Member
    Jun 8, 2007
    133
    please refer to the following post:
    http://www.3cx.com/forums/time-out-when-dialing-5949.html#p28431
    it discusses the issue in detail.
  3. techworx
    Jul 22, 2008
    17
    Hi Thanks for the reply,when i click on the link ,i get this message "You are not authorised to read this forum."
  4. ess
    ess New Member
    Jun 8, 2007
    133
    Sorry, I just wasn't thinking when I linked that thread.
    Here is a recap of the relevant posts in that thread:
    From Me:
    From kevin:
    From Jparisi
    From ra81:
    So, if you're using a free version, the provisioning update does not help you much. However, you can mess with those inter digit timeouts to try and find a balance (acceptable delay).
