Linksys SPA921
Discussion in '3CX Phone System - General' started by fraggle, Sep 26, 2008.
  1. fraggle
    Sep 22, 2008
    17
    I have the above phone. I set the oublund rule up in 3cx to that you dial # to use voip.
    When I dial # the phone ends the call immediately
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Because of dial plan
    use numbers better
  3. nmartin
    Sep 25, 2008
    As amygoda sys, it's to do with the phone's configured dial plan. Download the phone Administrator's Guide at http://www.LinkSys.com and look at the section:
    LinkSys IP Phone Field Reference -> Ext Tab -> Dial Plan
    and you will see a description of how the phone matches the dialled number against its 'acceptable' number format (a bit like a regular expression match statement).
    By playing around with the expression you may be able to craft a dial plan to match your requirement. See http://en.wikipedia.org/wiki/VoIP_Dial_Plan for more information.
