Linksys SPA941 Phone Restarting
Discussion in 'Windows' started by infotrust, Apr 13, 2010.
  1. infotrust
    Apr 1, 2010
    Can anyone tell me if the system restarts this phone? As I have noticed that this phone does a restart every 3-4 hours, I have also had that it has cut me off during a telephonic conversation and restarted...
    Is it software related or the hardware (phone) related, i.e. have I configured the software somewhere to restart the phone at a specified interval?
    Any help PLEASE...
    THANKS!!!!!!
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    I use 5 of these phones and have not seen this myself. I have heard of this happing, it was realted to them having a bad power problem though.
    Do you have all static IP's for the server and phones?
  3. leejor
    10,356
    224
    Is the set running the latest firmware? You could try a factory reset and then just provision, manually, the basics...see if it still does it.
  4. vpaulo
    Jun 24, 2009
    23
    You use POE or external power for spa-941? and what version of spa are inside your phone?
