Linksys SPA941 re-invite
Discussion in '3CX Phone System - General' started by muaddib32, Feb 21, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    Apparently the Linksys SPA941 handsets do not support re-invite. This means after completion of a call transfer the extension number of the extension that performed the transfer is still displayed rather than the external caller ID.
    Is there a way around this? I have tried selecting and deselecting supports reinvite and replace header on the extensions but regardless of which way it is set it doesn't work. Is there anything else that can be changed, perhaps on the handsets, to get this to work? This feature worked fine with these handsets and the SPA9000 that was previously installed.
  2. StefanW
    Jun 2, 2009
    1,215
    87
    unfo not. V10 will help you a bit in this point if you need to use *20* for a call pickup.
    the caller id will be send.#
    on my cisco spa 50XG models it works to get the caller id. but i can not be sure if this works as well for the linksys spas...
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    The 942 and 962 do not do this out of the box either.
    I havent looked if there is a setting in the 942 itself to change - I will look later today and get back to you
