Linksys SPA941 still ringing after call terminantion
Discussion in '3CX Phone System - General' started by kkuhar, Apr 3, 2010.
  1. kkuhar
    Apr 3, 2010
    Hi!
    I have phone from the subject which still rings for 30 seconds after 3rd party hanged up.
    SPA941 is configured with provisioning.
    Pretty wierd situation since in logfile I see:
    22:52:39.911 [CM503008]: Call(33): Call is terminated
    All other function work normal.
    Any clues?
  2. kkuhar
    Apr 3, 2010
    I have found the cause of this behaviour.
    PC had defined two IP adresses and for some reason windows firewall (Win7) blocked some part of traffic comming from 2nd IP.
    Solved.
