Linksys SPA941 with 3cx
Discussion in '3CX Phone System - General' started by afpr, Oct 9, 2007.
  1. afpr
    Oct 9, 2007
    how to configure my linksys spa941 to make calls with 3cx phone system?
    thanks
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  3. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Note
    For mwi to work you have to set to NO. Yes it is strange but just tested. This phone does not need a SUBSCRIBE to MWI and therefore it is very misleading. Setting it to yes will have the MWI light remain ON constantly whether or not you read the voicemails or not.
    BRGDS
  4. LORD ORION
    Jul 23, 2007
    39
    I am using a 941 at home... the 921 guide should be adequate to setup registration.
    The only difference I found is that there is only 1 entry for the 3CX server address on the 941, instead of 2 (the extra one in the 921 menu being for outbound proxy)
  5. nb
    nb Support Team
    Jun 7, 2007
    2,117
    145
    Ignore outbound proxy for now
  6. afpr
    Oct 9, 2007
    thank you for all
