Linksys SPA962 Internal calls
Discussion in '3CX Phone System - General' started by Phthisicus, May 2, 2009.
  1. Phthisicus
    May 2, 2009
    6
    I have succesfully created a connection with my linksys spa962. And i have succesfully created a connection with my provider.
    I can make external calls to all phone numbers.
    I used the default manual on the website for establishing a connection from my spa962 to the 3cx system.
    Only when i can't make internal calls with my spa962.
    Does anyone have a suggestion. I think it hase somthing to do with the dialplan.
    My dialplan is "[x*]."
  2. ciscotech2007
    Jan 27, 2009
    94
    That dialplan should be ok... you can test it by taking the dialplan completly out... (save the dailplain in a notepad document to restore it later).
    But first thing you need to;
    How do you know you cannot make internal calls?
    Are you getting an error message?
    What other internal endpoint are you trying to call? Is that endpoint registered as a 3CX extension?
    Also, post your 3CX server log when your 'internal call fails'
  3. Phthisicus
    May 2, 2009
    6
    Ok thnx for the reply :)
    I found out that i didn't set my Provisioning settings.
    i can make internal calls now.
    Only this time on line 1 there is a envelope showing and the red light is burning on the top of the phone. That indicates that there is a voicemail message. But the voicemail box is empty.
