linksys vs GrandStream HandyTone 488
Discussion in '3CX Phone System - General' started by jits04, Jul 25, 2007.
  1. jits04
    May 2, 2007
    76
    Dear all,
    I'm using Linksys spa3102 in Italy. This device is not be able to manage all calls without echo problem. For home user is ok,but not for company(read a lot of post in Internet). Who agree with me? Who is using GrandStream HandyTone 488? What about it?
    William
  2. Anonymous
    Anonymous Guest
    I am using SPA3102, and several customers of mine are. No echo nojitter
    Works like a dream, mos of 4.4 or higher.
    So I have to disagree with your statement :).
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    We tested HT488 before. Not too much echo. For smaller office use should be OK.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Adding on to this - what would be better for 4 analog lines? I was going to order the GrandSteam GXW-4104. How does that compare?
    Eventually (month or so???) the 4 analogs will be cut down to 1 and adding a few VoIP gateways.
  5. gregitx
    Jun 17, 2007
    18
    I am using a Linksys SPA400 with no problems or echo
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I tried that with the SPA9000 and had echo and dropped calls and calls that didn't answer. Could have been 9000 issues? But support couldn't (and still haven't) been able to come up with a solution.
  7. gregitx
    Jun 17, 2007
    18
    yeah that is why I shelved the SPA9000 as well - lack of support !!
  8. gregitx
    Jun 17, 2007
    18
    But the SPA400 seems to work well with 3CX - so far
