linksys wip-330
Discussion in '3CX Phone System - General' started by nateb, Mar 20, 2008.
  1. nateb
    Oct 19, 2007
    68
    amyone have any experience using this phone? or any wireless sip phones?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Tried wip 330. The voice quality not too good. During conversation the temperature of phone body is very hot. Finally, we give up using this WiFi phone by using ATA with DEC phone instead.
  3. Branzov
    Mar 27, 2008
    Wip330 - voice quality is bearable in a high-quality and clean WiFi network. But there are other problems.
    Battery lifetime is about 12-14 hours at about 30-40 minutes talk-time. We have implemented some Wip330's in a warehouse where talk-time was 120 minutes on every 8 hours. Battery lifetime went down to about 7 hours :x
    We have tried SMCWSP-100 - same results and uglier design. WiFi is a real power eater.
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I'm using Nokia E61
    it works fine exept some small codec problems
    and thanks to “arpa” for his post to explan the settings
    http://www.3cx.com/forums/wifi-voip-phones-2715-15.html
