Linksys WRV200 Router has lost connection and DHCP issues
Discussion in '3CX Phone System - General' started by lonestar.computer, Apr 24, 2008.
  1. lonestar.computer
    Jan 27, 2008
    16
    A while back we were having customer problems with one-way talk path. 3CX recommended that I switch the customer to a Linksys WRV200 (see earlier ticket). This appeared to solve the problem, but now I am having major issues with the router. I looked on the internet and this is a common issue with this model being unstable with VOIP. Do you have more stable hardware recommendations for the customer router?
    Every day since the customer has opened their new office , they have been working OK on their new 3CX system in the AM after I reset the router, then after a while the router loses its brains or something and I have to reset it again. The router also seems to be renewing its DHCP leases every day even though I have set the timeout to the max.
    You guys recommended this router - whats up?
  2. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    We use Linksys RV08 & RTP300 with no problems.
    ecwilson
  3. scousens
    Jun 21, 2008
    9
    Lonestar, please check this ==> http://www.3cx.com/forums/remote-extension-registration-5860.html
    Probably you can help me.
