- Joined
- Oct 1, 2015
- Messages
- 99
- Reaction score
- 31
Hey Guys,
Trying to update to SP3 from beta on linux and getting the following error
Reading package lists...
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: postgresql (>= 9.6) but it is not going to be installed
Depends: libssl1.0.2 but it is not installable
Depends: libicu57 but it is not installable
Depends: libcurl3 (>= 7.52.1) but it is not going to be installed
Conflicts: libssl1.0.0 but 1.0.1t-1+deb8u7 is to be installed
E: Unable to correct problems, you have held broken packages.
Rollback to 15.5.8291.3...
3cxpbx is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded
Any suggestions on what I should do as I'm fairly new to linux
