Linux Deployment IP Phone Background
Discussion in '3CX Phone System - General' started by flex2, Jan 3, 2018.
  1. flex2
    Dec 12, 2014
    Would anyone with some better linux background know how I can change the background image that the IP phones pull from the server? I can do this easy no problem in the windows deployments, however I very green to linux and under the hood I get lost.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    523
    12
    try with this: /var/lib/3cxpbx/Instance1/Data/...
    You can also SSH to Debian 3CX with WinSCP and browse the files
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Try:
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/**provisioning_directory**/logo/
    You will also need to create a custom template for your phones.
    Gaucho713 likes this.
  4. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    932
    151
    You technically don't need any linux knowledge. You can host the background images anywhere. There's no requirement for the images to be on the PBX.
