List of GSM VoIP Gateway
Discussion in '3CX Phone System - General' started by awad, Jul 10, 2012.
  1. awad
    Jul 10, 2012
    Hello Everyone
    Does 3CX support GSM VoIP Gateways if yes then anyone can provide me the name of 3CX official supported GSM Gateway please.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Go to the blog and do a search for gsm gateway, it will return a few that are either supported or have been successfully employed by others.
  3. awad
    Jul 10, 2012
    I found this from Blog Search IMPORTANT: This guide is NOT a supported device. This guide is intended as a guideline only, and will NOT be updated. http://www.3cx.com/blog/voip-howto/2n-voiceblue-next-gsm-gateway/
    Dear I'm looking for 3CX Officially Supported Device
    Portech customer service is pathetic so I want to hear from 3CX professionals about GSM Gateways.
  4. lneblett
    Sep 7, 2010
    2,083
    61
    You also would have found this link
    http://www.3cx.com/blog/support/configuring-voip-gateways-and-cards/
    Portech is the only official brand, but others are known to work.
  5. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    What about Beronet, it is officially supported and preferred brand ?
    Regards
  6. lneblett
    Sep 7, 2010
    2,083
    61
    Eagle2,
    But apparently not for gsm, or at least not mentioned specifically as such.
    My guess is that there are several makes that while not supported officially, are in use and have some satisfied clients who have already blazed the trail with 3cx; hence why I suggested the blog search. Having said that however, I do share the concern about the risks associated with using a non-supported device.
  7. StefanW
    Jun 2, 2009
    1,216
    88
    yes beronet is, and the GSM Modul is supportet in any confugration.
    the setup assistent also detects the GSM Module and offers to create LCR to the GSM cards if a mobile line is called.
    other calls will be routet then to ISDN or FXO
