Listen in
Discussion in '3CX Phone System - General' started by cylosoft, Oct 2, 2010.
  1. cylosoft
    Sep 9, 2010
    13
    Is there a way to listen in on an active live call.
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    Yes. You use the "barge in" facility accessible from the call assistant. Download call assistant and try it. It shows the calls in progress, allows calls to be transferred, barge in to listen in and the ability to create conferences. This is ideal for a receptionist or manager.
    Kind regards
    Richard Crabb
